Re: How did my outboard get holes in the pistons?
Okay, as Pleasure Boat Junction mentioned, see if air can pass through the holes. If not, then I wouldn't worry about the pistons. You stated that the cylinders look good, so I would then check the reed valves. If the reed valves aren't working right, then you won't have any compression. Check the head and make sure that it is not warped, otherwise, you'll lose compression into the water jacket and yes, the reed valves are in the intake manifold. If you want a better look at the pistons for scoring, pull the bypass covers off the motor and you'll be able to get a visual through the intake ports. Typically, anything that will likely score the pistons will start there. If the pistons look good, then it's likely that they are not the problem.
