How does this come apart ?
monriverguy
P5060074.JPG P5060073.JPG P5060070.JPG P5060069.JPG I am trying to replace my dash board on my 1959 Lone Star El Dorado not sure how the drum comes off. Is it pressed on ? is there a key ?
Please help ! Thanks to all
GA_Boater
You have to take the steering wheel off and undo the large nut - kind of like the one on the back side in the 3rd pic.. It has to come off anyway if you want to put new wood around the shaft.
monriverguy
Ohh so i dont take the drum off then that nut? i should take off the steering wheel to get to the other side? how does the steering wheel come off ? can i put on different kind of steering if i take the hub off?
sorry i am new to boat steering i have always had a tiller.:)
Fed
Undo the rusty nut and take the drum off, it's probably on a taper with a key.
GA_Boater
If you take the rusty nut and drum off, the shaft is still going through the wood dash. It all has to come apart.
The center of the steering wheel probably pries off to get to the big nut and key behind the wheel.
If you want to upgrade the steering, stop now and don't worry about getting it all apart. As long as the existing dash can be used for a pattern, you won't need it or the old steering.
