How fast should my bass boat go?
phillipdi
Hello, I am trying to figure out how fast should my 1999 triton tr-17 bass boat with a 1999 90hp mercury outboard should go. I have topped out at about 39 miles an hour. Is that about correct?
Faztbullet
Re: How fast should my bass boat go?
Pretty close depend on load and prop...... below is from owners at BBC
2012 Triton 17 Explorer
2012 90 Merc 22 Laser II, Motorguide 50#. 50 mph @ 5250 rpm (gps).
mr 88
Many variables from load to prop SS-alum 3 -4 blade, to GPS speed or boat speedo. What is the max rpm on the engine vs what your tach is reading,that is pretty much the starting point.Without that info your speed may be a few mph slow or spot on.
CharlieB
Age of the boat makes one wonder if there is any added weight from water-logged foam, more gear stuffed into compartments, big fat owner/pilot like me. All adds up quickly and slows the boat.
phillipdi
I dont know it goes the same speed with 4 guys on it or just me. I was just wondering I have an aluminum prop that I beileve is 23 pitch. Also the speed I go off of is on my GPS system.
M
Maxz695
Guest
As stated RPM,S are a major tool in adjusting the pitch and diamiter of the prop. You may be running 39 MPH that take longer to get to and stressing the hell out of the motor with 4 guys in it when you could be doing 39 MPH in half the time with less pitch and having your engine run at top RPM,S recommended for your engine and creating less stress on the motor. Get a Tach
5150abf
Seems to me you should be alittle on top of that, more like mid 40s but that is just a guess on my part, and no, the boat will not run the same speed with 4 guys in it, weight kills speed.
As stated, could be engine not running at it's prime, waterlogged foam, wrong or dinged up prop, engine too low, lots and lots of variable to check out.
You need to start wth wide open rpm and go from there, outboards are built to run a specific rpm and speed falls where it does once you find that rpm.
Is this boat stored inside or out and could it have waterlogged foam, that can beseveral hundred pounds and wiil certainly slow a boat down.
jestor68
With an aluminum prop, that may be about right.
That boat should run 43-47 mph with a Quicksilver Lightspeed 13.5 X 20 prop. :)
Note: suggestion based on the Mercury prop selector. The Quicksilver Lightspeed is the same as the Mercury Laser. :) 1999_triton_tr_17_for_2_300_19669462.jpg
dan02gt
You should be getting mid 40s out of that setup, but it's never going to happen with an aluminum prop. Bass boats need lift to go fast and I be you're getting none with that prop. It just doesn't have the cup to lift the bow and reduce your wetted surface area. I would recommend a Laser II or Trophy Plus for your setup. Both around 21P.
Check out this link for the Mercury Prop Selector: Prop Selector | Mercury Marine
You'll need your max speed and RPMs for the best results, but it will give you a good place to start
Texasmark
We need some more info: weight, prop type, specs and pitch, hull shape, like does it have a pad, weight, altitude, weight....
Texasmark
I just went to my prop slip calculator www. "go-fast.com/Prop_Slip" and plugged in: Gearbox (2.33 which it is... I have one a few years later in production), Pitch (stated to be 22), and RPM (stated to be 5250) and the result, if you punch the "Calculate the Theoretical Speed" button comes up with 47 mph. That's before you factor in any kind of prop slip.
So sir, somebody fed you a can of worms.
Mark
dan02gt
Mark
I agree. Those are common 115hp numbers, but not possible with a 90.
Campylobacter
Largemouth Bass have a burst of swimming speed of about twelve miles per hour, but their sustained swimming speed is much less.
You should be fine.
tinkerguy70
You should be fine.
You mean you have to run them down to catch them? MAN! No wonder I'm such a crappy fisherman...I've been doing it all wrong!
pikefisherman
I agree with tinkerguy I have had some luck troling for pike and landed a few Bass, but my old 9 horse wont do any where neer that!!
Campylobacter
Wait, so your telling me you can catch fish in a boat thats NOT moving? Why do the bass boats on my lake all have 200's?
