Long Thread ---- I have been considering changing out my 79 OMC Stringer 800 out with a Merc Gen 1 305 Chev, I know alot of work. well it seems that there are alot of OMC guys that have been keeping theirs running with a lot less work than the swap. I am very mechanically inclined, with some physical limits. I have had two companies in two different states take a low hours well running unit and mess it up. Now I have a good OMC guy but cannot afford to pay his rate for everything. The drive is now a mechanical,with another different interrupter. It has a month of use on it as it was down May & June. I have an issue that I am having trouble with it dying when it comes up to the slip, good thong my dock box has give, when I back up out of the slip and try to go forward it dies, very dangerous to me and others,this is when the engine is warmed up. I redid the transom stringers and floor with some help, bad advice was to keep the low hour OMC at this time as there were alot of Mercs and Volvos around to replace it with.
At this point I'm thinking I'll run it till I can't get or afford parts. Alot of folks say don't buy a used OMC, but I have one and a used boat,Merc/Volvo, might be available as money better spent in a couple of years while I keep this one running. I purchased this boat new in 79 I thought I knew about its upkeep,kept garaged or covered, changed fluids etc. until I found the rot, and had the motor and drive looked at. The hull is now very solid a deep Vee. I appreciate any opinions.
