KnotConnected
- Joined
- Aug 15, 2012
- 221
Quick Question.
If you haven't been following my plethora of "how to fix X" and other problems i've been having, corosion has been a big troublemaker for me this spring.
My outdrive has 4 anodes, the two on the trim cylinders, the flat round skeg anode, and the U shaped anode forward of the outdrive. Boat went in the water ~may 15th, and I'm already starting to see a little bit of corosion on the surface of the trim pump anodes (the only two I can clearly see while the boats in the water). They're no where near needing to be replaced yet, but they are clearly showing a bit of corrosion on the surface. Is this normal, or could I still have an issue thats causing them to waste a way a bit?
At this rate I'm probably looking at replacing the set of 4 every year.
(Fresh water, 1994 Larson Cabrio 280, single 7.4L Bravo III, hooked up to shore power 24/7)
