billywhizz
Thread starter- Joined
- Nov 22, 2007
- 174
How many times should my engine turn over before it starts? always starts fine when cold but once out to sea and drifting a wreck or starting after 20/30 mins it turns over between 6 and 10 times before it starts? is this normal for a 25 year old engine? the spark is weak, orange, instead of thick blue, the engine has 150psi on all four pistons ,new cylinder head,runs fine, new leads , points, condensor rotor arm, distributor cap, all set correct. I have 9.2 volts on the+ side of the coil and 7.6 volts on the - side have tried a jump wire from battery + to + side of coil, but made no difference to starting, also have got fuel pipe well away from any heat source, checked for voltage drop between battery and starter post (none) now i am stumped!
