how much deflection should a driveshaft have on a 2008 DF150
wpowell323
i have a 2008 DF 150 with a clunking when it is in gear. It is a constant clunk, clunk. clunk in forward or reverse. There is no metal in the oil, but there is about 1/8 of a turn on deflection in the drive shaft when in gear. I was wondering what the acceptable amount of deflection is and is this possibly a shim problem or a problem in the clutch? The motor only has about 60 hours on it. At the very least if someone has a link to the manual for this motor that would be great!
clanton
Re: how much deflection should a driveshaft have on a 2008 DF150
Does the clunking go away above idle?
