How much water if any?
ruf1967
Re: How much water if any?
Check your bellows and see if it is cracked or damaged in any way. Check your hoses on the engine as well. They can develop pinhole leaks over time.
oops!
I recently finally (because of reding someone elses post) found where I was getting water in the boat. It's leaking through the rivets under the rub rail and running down the side in a couple of places... The outdrive stuff is more likely and really important to check as it can cause a lot more damage if it's leaking and not handled properly...
amazing how hard you can work to make everything watertight and it still finds a way to get in... [/QUOTE]
man ....water is a weird substance....it gets in any where......im suprised dams dont leak.....
ok.....i/o 6.......put the muffs on it in the drive way.....rev it up to 1500 rpm and stick your head in the doghouse....or just remove the thing and have a really good look.......first examine every hose clamp....then look around the drain plugs/shuttle cocks in the block? under the exauhst mani.....now look farther back....near the transom....look for any water drips
if you find any drips....post back here.....if you dont.....do the same tests on the water at low speed then at plain......(uh....make sure someone else is driving :eek:) be really careful when you do this.....if you hit a wake....you might get pilled into the pullys....so be real careful....real real careful...
then post back with what you saw
gmayes
Thanks again for all your help. I'm going out on Monday so I'll post back then.
zach103
not trying to steal the thread.. but we went out today.. first lets start here.. last night i put the cover on. its a walmart cover with a couple tears.. not pefect.. and the boat was sitting level (ready for this morning). well it rained for a while last night. and a bunch of water got in the boat.. soaking the carpet etc.. well we left the plug in too last night. so we took it out this morning and the bilge came on for about 5 seconds . so we pulled the plug. it was gushing but its a little small steady stream and its been going for a couple minutes now.. like you know i just redid the deck and glassed everything down.. im realy worried right now.. im really hoping that its just from all the rain last night.. like i said the carpet was completely soaked.. Please tell me i shouldnt have anything to be worried about
zach103
forgot to add that one place for the water to go is an opening to the middle of the boat up by the walk thru.. well we put foam underneath and on the sides of the inboard gas tank.. could it be getting stuck up front and not able to pass thru that foam.. we forgot to put something under the tank so water could run thru. is that the problem?
