how to change oil on a 125hp 1989 force
dmas
Hi everybody
I was wondering if to change the oil I have to fill it from the bottom screw or can I use the top screw that says "fill" next to the "vent" screw, because I've read on lot of treads that you should change your oil using a pump thru the lower screw...
joshdashnaw
Re: how to change oil on a 125hp 1989 force
Feeling it from the bottom up insures that there is no air bubbles in there. The pumps are cheap to purchase.
dmas
thanks seaman, also got an idea where can I find the water pump housing? mine is plastic, part of the plastic tube broke down when trying to install the lower unit back into place, you think I can glue it back in?
joshdashnaw
I'm not sure about that, but I wouldn't glue it. I'd replace whatever broke. Probably needs replacing anyways if it is breaking easily. Good idea to replace impeller why you have LU off if you haven't done that.
dmas
you are right, it's better to replace the plastic housing, found one on ebay used for $30, I will replace seals and impeller also, thanks for your help..:D
