Re: How to clean carbs?
Best way is to get a gallon can of carb cleaner with a dipping basket- I use a soaking carb cleaner made by Berryman, has about 3 qts of cleaner and a basket in a gallon can. This is some pretty potent stuff, so make sure you are using rubber gloves, and not the flimsy latex ones.
Get a service manual. Read the top secret files at the head of the forum.
Take apart the carb, incl the jet(s). Soak over night. Rinse off carb cleaner with water, blow out all passages with water and reassemble with a new float and new gaskets.
