How to inspect oil pump?
GeoRXT
I assume the 2 cycle outboards have one. I want to make sure the one on the boat I just bought is in near excellent operational condition. I don't want to have to rebuild and engine because the oil pump went bad when the motor is in great condition.
Any help appreciated.
slasmith1
Re: How to inspect oil pump?
Your engine oil is mixed with your gas in a 2 cycle engine. So no oil pump unless it is an injected system then the pump just mixes oil with gas for you.
GeoRXT
It is a '96 Mariner 125hp...So I should not be worried by it. I've had the oil pump go bad on my 2 stroke ski and lost a piston :(
slasmith1
not sure if that is an injected engine or not do you mix your oil in your gas tank or do you have a seperate tank for the oil?
GeoRXT
I have a separate tank for the oil...
