how to put a bilge pump in
brianis
ok so first fiberglass boat 58 starcraft fiber floor and all so i noticed a few patches on the hull cant really tell if it leaks or not so thought it would be a good idea to install a bilge pump just to be safe question is where and how should i cut the fiberglass to install
skargo
Banned
Re: how to put a bilge pump in
You shouldn't need to cut any glass to install it.
DustinJean
only cut should be if it doesn't have a hole for the drain out you will have to drill a hole for however big your bildge hose fitting needs
NetDoc
I have the same question since I am installing a SECOND bilge pump. Its obvious that you put the exhaust above the water line, and I could vent it right beside the other one... what are the other considerations I am missing?
NetDoc
The bilge pump there already is not mounted at all. Should it be?
Yacht Dr.
Depends ..
If you have a rule pump .. you can clean and 5200/4200 the red Strainer cage to your hull. No screws needed.
Because the pump cage has tabs to clip your pump to you can replace/maintain your pump.
But yes .. you need to secure your pump somehow :) .
YD.
brianis
guess i need to explain mine a little more there is no access under the floor on my boat so i dont know the condition under it not sure if its all foam not sure whats under there at all and it seems to me like the rear drain hole is kinda high but not quite sure this is my first fiberglass boat so lots of questions
Seasonally.boating.jon
Brianis, My boat had a 4"x4" block, about 3/4" thick glassed to the bottom of the hull. Pump was screwed to the block with short screws. This was factory. Install the inspection pie first ofcourse. Shouldn't be that big of a job but might be alittle tight. Good luck man.
PS: just reread YD post, glue the cage to the hull is super easy. sorry, just trying to help:redface:
brianis
if i install a inspection pie did the foam insert deals go every so many ft in the boats i can tap the bottom to find the brace but kinda hard because theres glass over the wood dont want to start drilling holes and hit foam every time .
Yacht Dr.
There is no way of knowing if your whole bottom is foam or not ( unless someone here has intimate knowledge of your boat ).
Knocking around with a rubber mallet will help determine if you have stringers/bulkhead at that location .. but not a whole lot of boats have stringers running down the center of the boat.
Got pics :) .
YD.
