How to remove back drag tube for carb rebuild?
deerhuntre
Is there a trick to removing the plastic fitting the back drag tube is connected to the carb with?
Clams Canino
Re: How to remove back drag tube for carb rebuild?
What carb? What model outboard? What approximate year?
You gotta put the model in the header of the post if you expect it to get read at all , let alone answered.
-W
deerhuntre
Sorry. 1986 Merc inline 6 115. Side float back draft carb. Is there more info that is helpful?
Clams Canino
All you need to remove to properly clean those carbs is the rubber tube, the main jet cover, the float bowl cover and the idle needle. Every possible passage can be sprayed with just those removed.
-W
