how to remove old decall from cowl
1983rinker
What the best way to do this so I can repaint cowling?
Bifflefan
Re: how to remove old decall from cow
You can try one of those wall paper poking rolly things, that the technical term for them I think. Then spray it with fabric softener.
That should loosen the glue to get it off.
There are also chemical strippers... but I dont like to use them unless they are needed.
A product called "Sticker Off", doesnt work for poopy, and cost a ton.
1983rinker
Will a heat gun work too????
mark1961
Ensign
Yes, it will soften the vinyl/glue so its not as likely to tear/crack when being peeled back. I actually managed to remove my 82 Evinrude ones virtually intact albeit stretched using a hairdryer, you will definitely get bigger pieces off at a time using one, it will take patience with a decal that size though. There may be some glue left behind which can be removed with a suitable solvent.
tallcanadian
A heat gun works awesome. You could probably pick one up for around 20 bucks. It will save you hours of work. Decals will peel right off. Here is a couple pics of mine.
Before
During,
After,
Bob_VT
That's allot of decal to remove....... take lots of pictures....then sand it off. Since you are going to repaint anyway....... a vibe sander will make very short work of it.
eaglejim
Hair dryer and a plastic scrape that is how I did mine,once it gets warm it will come off pretty good
fat fanny
Heat gun works every time along with some patients and time then clean the leftover glue off with a good hand sanitizer
beckspop
Ppop
You might also try "goo gone" instead/in addition to the sanitizer.
1983rinker
Thanks all. Heat gun it is.......
eavega
+1 on the Goo-Gone. I used that to take the old hull numbers off my boat when heat gun failed. Old numbers came off lickity-split.
-E
1983rinker
I used the heat gun and all came right off. Now to remove the sticky stuff. I will get goo gone tomarow.
1983rinker
I'll try that. We make hand sanitizer and my job so it will be free. That the best FREE..
tallcanadian
All I did with the residue is heat it up a bit with the gun and rubbed my thumb over it and it peeled right off.
1983rinker
Re: how to remove old decall from cowl
Got most of it off today, will finish tomarow.
1983rinker
Took most of it off today.
1983rinker
New photos. I used a glue remover.
pmillar
Believe it or not, wd40 works great on some (not all) adhesives once the decal is removed. It's worth a shot if you have a can sitting on the shelf.
1983rinker
This is trure...
mark1961
Ensign
WD40 is full of silicon though which will still be there even after sanding and prep, new paint and silicon hate each other, i would avoid using it, jmo.
