How to remove seawater pump on aq271c?
LadyAnya
I noticed a small leak at the seawater pump today and decided to check it out. I was able to remove the impeller and housing from the crank pulley, however I can't seem to separate the impeller housing from the part that bolts to the crank pulley. How do I separate the two?
zbnutcase
Re: How to remove seawater pump on aq271c?
You dont, you remove the three allen head bolts to remove pump, and some of those pumps are toss-aways, no repair parts available.
LadyAnya
I was able to separate the two parts. Does anyone know were to get a rebuild/repair kit?
Ayuh,... Sounds like ya Don't..... ZB is rarely wrong on this stuff...
Don S
Check with NAPA, they used to have the Jabsco replacement pump, brand new for just over a 100 bucks.
The pump housing where the impeller makes contact is probably wavy and worn out as well being 20 some years old.
