How to replace AQ125A raw water pump sealing ring #12
nic420
I am trying to replace the AQ125A raw water pump sealing ring #12 and have a couple of question. The seal has a front and a back side, which way does the seal go in? Is there a trick to getting the seal in without pounding it with a rubber mallet? Thanks.
Don S
Re: How to replace AQ125A raw water pump sealing ring #12
Need the picture you used to know what seal number 12 is.
wellcraft19
Never us a mallet, gently press it in.
Don S
The lip of the seal faces the impeller (Towards the water).
I normally gently tap the seal in with a hammer keeping the seal as square to the bore as possible.
nic420
Thank you Don! Thank you: for all the advice you have given me on this thread and my other threads.
