Re: How to run depthfinder/GPS wiring(2004 Fishhawk)?
Like Burroak said, if the old transducer cable is still in the cable chase tie a strudy string to the free end and pull the transducer cable out the back. I've done it a gazillion times and is never a problem. If you think about it, how would anyone get into the chase to put zip-ties on? When the get the string through, tie it to the new cable and pull it through. DO NOT tie the string to the plug. Wrap the string around the cable about six inches back from the plug and then wrap that six inches with electricians tape. This will allow pulling on the cable rather than the plug. Wrap the tape a little past the plug so you form a tapered leading edge so the plug doesn't snag on anything.
