How to start old johnson
Tourtney
Hi guys I need a little help starting an old johnson for the first time. I noticed the cylinders look dry and that the carbs on that side are closed when I try to start it. Everything I have read says to keep the outboard in neutral so that side of the carbs are closed. It is a 1970 60 hp. It is spinning fast and has new spark plug wires. Every now and then I see a little bit of white smoke and a little puff noise but that's all I'm getting. The carburetors have just been rebuilt and I see fuel sitting in them.
175se
working on one of those now, does it have spark, if not does it have 9&1/2 volts from the amplifier.
Tourtney
No. I'm just checked all three one by one by holdong the plugs to a ground metal while craning. Nothing... How do I check power pack voltage. Is it the black and whit wore going to the flywheel?
175se
No it should be the purple(or violet if you prefer) on term #5 from the left.
Tourtney
Well, if the black and white wire is it i measured 1w.6 to the amp and 5.38 at the black and white wire
175se
Well then you should go to the cdi site they have a good tblshooying sequence for that engine( im sure others can direct you there)
Tourtney
pretty sure its a magneto ignition. I've got the flywheel off and I'm going to try and adjust the points now.
175se
Sorry i should have added at cranking. The amp has to see that in order to fire.
Tourtney
Did what gold ole Joe Reeves said by taking the coil and touching the ground together with the pack/amp. I got a big blue spark from up to 1/2 an inch away whereas Joe said 1/4 inch was fine. So i think I can rule out the pack. I know I can rule out the coil because it is new.
jimmbo
A 1970 60hp would not have a Magneto Ignition. It has a points fired battery CD Ignition
Tourtney
Here is what I'm looking at now if anyone is curious.
Yes , that is what it looks like.----Have and have seen many of those.----What is YOUR next move on this motor ?
Tourtney
.01 inches, already adjusted them. That's what it says on the distributer.
