How to test for spark without cranking engine ?
carlos515
Is it possible to test my Thunderbolt IV without cranking engine? I went to start the engine and found my carb leaking. But had no fuel on plugs . I will rebuild the carb , but i think I should check my ignition also.
I can't just crank the engine because of my new flat tappet cam. So I am at a lost as to how to check the ignition system.
Just found how to test system........In Adults Only......Sorry should have checked first.
carlos515
I tested the ignition and rebuilt the carb. She sounds good at 2000 rpm.
poconojoe
That's going to be a problem. How are you going to start it without cranking it?
Yeah, I was wondering the same thing.
Maybe he has some new fangled instant running engine that doesn't need to crank first. :D
as long as you prime the oil system, used assembly lube during the build and pre-filled the lifters with oil, you can crank it. however based on post #4, its running.
