pscrabber59
Thread starter- Joined
- Apr 12, 2010
- 246
I have a 2005 Yamaha 25hp four-stroke. When last run 2 wks. ago while flushing motor water was luke-warm to warm with a sometimes spuddering pee-stream, not the steady stream I'm used too with this motor.
So I took the T-Stat out and I really don't know how to ck & see if the T-stat is working or not. Do I need any special tools? I'v read where your suppose to drop the t-stat in some hot water and see if it moves or opens up. Is this the usual way to ck?? I will also change out the impeller after the t-stat fix.
Any advice is always appreciated
