Re: how tolower lu.
hello,<br /><br />I removed 3 bolts right at trim tab, and dropped down about 1 inch. and i see the housing of water pump. I used to replaced impeller on 1980 15hp Evenrude. by removing bolts and put the gear in the right position and it dropped even lower. I just don't understad about this model. is any shift rod that i need to disconnect?<br /> any info will be appriciated.
