hull extension in progress with pics
Status
Not open for further replies.
Robj
Re: hull extension in progress with picks
Yes, a few layers of mat would work, it's not that it's that weak, but the increase in strength when woven or stitched products are used is substantial. So if possible it would be nice to have it go over the top of the stringer. oops! has a chart with a comparison of 1/4' laminates made with mat, mat and roving, and a biax.
Would I be able to get a copy of that chart? Or is it in your cookbook, which I have already been given a copy of but have not yet reviewed it in great detail. We'll see later today how Oops did last night. Hopefully he had success.
Have a great day,
Rob.
redfury
Have a great day,
Rob.
That should be a sticky in this forum ( the cookbook- first I've heard of it, but it sounds like it's chock full of vitamins! :D )
redfury
You can buy half round moulding at any good trim shop. Your big box outlet might have it too. It's basically your large dowel cut in half lengthwise.
I was thinking of that too, but I don't know which curvature would work best to lay glass over....Half round would be easier I suppose and you'd end up with the train track look to the stringer more than just adding an inch to the top, you'd probably end up with more like 1 1/2 inches extra width which might be easier to lay up. I'd be more concerned with ending up with bubbles on the inside curve.
ondarvr
I got the Laminate strength chart from a friend that works for a major glass supplier. I had him send it to me when the strength of mat was being discussed in another thread. I wasn't able to post it due to limitations on our company lap tops, so I sent it to opps! so he could.
oops!
i been tryin to figgure out how to post that chart for a couple of weeks..!
this is the best i can come up with....but it makes little sence like this..
Vectorply Corporation, CCP laminate comparison
Laminate Construction
Laminate # -> 1 2 3
Name Woven laminate mat laminate Knit laminate
Layer 1 Gelcoat - 20 mil Gelcoat - 20 mil Gelcoat - 20 mil
Layer 2
Chopped Mat - 2 oz Chopped Mat - 2
oz
Chopped Mat - 2
oz
Layer 3
Chopped Mat - 1 oz Chopped Mat - 2
oz
E-LTM 4410
Layer 4
24oz Woven Roving Chopped Mat - 2
oz
E-LTM 4410
Layer 5
Chopped Mat - 1 oz Chopped Mat - 1
oz
Layer 6 24oz Woven Roving
Laminate Properties
Laminate # -> 1 2 3 Units
Laminate Woven laminate mat laminate Knit laminate
LamRot 0.0 0.0 0.0 deg. SI
Thickness 6.183 6.192 6.204 mm SI
Resin Wt. 4.32 4.59 3.83 kg/sq.m SI
SI
Fiber Wt. 2.50 1.87 3.69 kg/sq.m SI
Laminate Wt. 7.37 7.02 8.07 kg/sq.m SI
Vf 18.14 % 13.58 % 24.36 % by Vol. SI
Mf 41.47 % 34.64 % 49.18 % by Wt. SI
0? Modulus, Ex 1.09 0.73 1.62 MSI US
0? Modulus, Ex 7.50 5.01 11.14 GPa SI
90? Modulus, Ey 1.09 0.73 1.62 MSI US
90? Modulus, Ey 7.50 5.01 11.16 GPa SI
Shear Modulus, Gxy 0.27 0.27 0.30 MSI US
Shear Modulus, Gxy 1.84 1.88 2.07 GPa SI
0? Flex. Stiffness 144 98 241 N-m SI
90? Flex. Stiffness 144 98 241 N-m SI
0? Ult. B. Moment 960.2 753.8 1,556.6 N-m/m SI
90? Ult. B. Moment 960.2 753.8 1,557.7 N-m/m SI
N.Axis - X -0.55 -0.14 -0.53 mm SI
N.Axis - Y -0.55 -0.14 -0.53 mm SI
0? Ten. Ult. Stress 16.5 11.8 25.5 KSI US
90? Ten. Ult. Stress 16.5 11.8 25.5 KSI US
Shear Ult. Stress 5.3 6.2 6.8 KSI US
0? Ten. Ult. Stress 114.0 81.1 175.6 MPa SI
90? Ten. Ult. Stress 114.0 81.1 175.8 MPa SI
Shear Ult. Stress 36.8 42.9 47.2 MPa SI
0? Comp. Ult. Stress 14.8 16.4 29.8 KSI US
90? Comp. Ult Stress 14.8 16.4 29.9 KSI US
0? Comp. Ult. Stress 102.0 112.7 205.8 MPa SI
90? Comp. Ult Stress 102.0 112.7 206.0 MPa SI
ill ask a few of my buddies how to do it......
if any body knows...it is a file off e-mail
ondarvr
It may be possible to blow it up, print it, then scan it and post.
oops!
i might have to do that.......i think i need my puter gurus help....
i also posted it in website problems...our guys are pretty quick on that stuff
new_boater
if you need to share something that is to big or has other limits why not place it on a file share site and just place a link to it in your sig file
that is what i have done for several things in the past
oops!
any suggestions on what one?....im not too computer friendly
redfury
You can email it to me, I can manipulate it with photoshop depending on the format.
oops!
pdf....pm me your addy
drewmitch44
Any progress on that guys id like to see it as well.
oops!
i gotta go work on the boat now....update on the stringer wrap comin in a few hours.
oops!
btw drew...i been waiting for red to pm me but i dont know it he has seen this yet
wire2
Re: hull extension in progress with pics
I've read pages 16 to the end of this thread just now, and could see sharp corner glassing problem coming. Glass strands want to remain straight, period.
The pins were a good idea, but there's nothing to stop the wet glass from pulling up and elongating the hole, thereby creating a void.
If you use a staple gun instead, there's a definite clamp of glass to wood, it will be much less prone to shift up. You can resin around the staples, remove them after it kicks, then resin the spots.
Or, as Tony Soprano says, "fogedabowdit", and resin over them.
jameskb2
Yeah,
I was just mentioning it.
My plan is to use two by stock, (1 1/2" wide) in either cedar, or redwood. I'm leaning towards cedar. Cedar is light weight, strong, rot resistant, and holds paint or resin well. I'll then take a laminate trimmer, which is just a mini router, and use a 1/2" radius bit to round over the top edges. This will give me 1/2" flat on top for the floor, er, deck, with a nice edge to fold the glass over. I think it will go pretty well, but of course, I'm open to opinions! :)
redfury
I just PM'd you oops! though you are probably knee deep in it right now, or half schnokered in Coronas....whichever is fine by me! :D
I'm off tomorrow all day, I'll be in and out. I'm working on securing a way to keep both boats here permanently, and I just found out that I can build a 12x20 shed on my property. Walked it out, and if I have an 8ft wide door and build to the max 15ft height, I'm golden. One of the two boats will fit in just fine, the other can stay out and covered on gravel behind the fence...I get a place to work on the glastron rain, shine or snow to boot! So, I'm going to be doing a lot of measuring and conniving...err, planning on how I'm gonna pull this off. Just sent an email to the building inspector.
If he gets it to me by noon tomorrow though, I'll have it up here by tomorrow evening for everyone to look at.
new_boater
Glad to help:D:D;)
Status
