NatedoggAZ
Thread starter- Joined
- Mar 7, 2018
- 182
Hello Everyone,
Want to get some quick advice in how to install these....
New hydraulic manifold and new anode (mercathode removed)
Here is how I am thinking these components are to be installed:
1. Hydraulic Manifold Gasket (large)
2. Hydraulic Manifold
3. Plug insert through hole in manifold
3a. This is usually where the mercathode wires go through
3b. This plug and hole are tapered - so I guess I push this up from the bottom - small end going up first?
4. Small gasket
***5. Do I meed to use the small black plate (above the screws) over the gasket? ***
6. Screws to hold it all together on the manifold
7. Anode
7a. looks like I may need to drill 2 holes - one at top and one at bottom
7b. Anode is held on by 2 nuts and secured by those 2 nuts on pegs on bottom of bell housing
*** p.s. Those 2 screws are too short to go through the anode and secure into the manifold...***
...Let me know if this seems about right??
Thanks!
ND
4. Small gasket
7. Anode
Thanks!
ND
