Outback Jack
- Joined
- Apr 23, 2010
- 267
Well I could not believe it after I was getting the bottom of my boat ready for paint and marking the water line from the mark of it sitting at the slip for a couple weeks. I thought the line was off by 1 inch on one side...so i pulled up the carpet to do some tests on the foam and I found wet foam.
When I bought the boat last year the guy said he had an incident at the dock and had it repaired. I checked the repair and it looked good. I asked if it got wet and he said no. It was just above the deck height on the outside so I said he is probably right. You have to take his word and the price was right.
What really made my day was when i pulled the carpet up the manufacturer had a hole left open where they filled the foam. On both sides just under your feet .So it was never water tight from day one.
So I actually don't know if the boat got gradually wet from the manufacturer not making the deck water tight or from the dock incident.
The thing is I don't figure there is any rot in this boat as i did a couple test holes and got down to the bottom of the stringers and they are not rotting..actually the foam is only about half soaked.
What do you guys recommend on getting the foam dry or at least getting it out and replacing it.
I don't really want to tear up the whole floor, but if that is the only way I guess I will.
Anybody have any luck with doing a cut on center on the stringer and just putting the piece back in and fiberglass with matt over it all again.
Any suggestions form the experts would be well appreciated....and thanks in advance
Out Back Jack
Out Back Jack
