i don t t no the right prop size for my boat
zigg12001
can any one tell me the right size prop for my 1969 22ft cheiftain.
zigg12001
140 mercuiser there wasnt one on it so i dont no any thing about it
556guy
My father in law had one of these before I married his daughter. Memories!! Love to see pics.
jbcurt00
Very rarely (if ever) is there going to be 1 prop that will fit every boat w/ a given motor for every buyer.
I don't know about every motor, but certainly almost all motors can use a variety of props in different pitches & diameters.
A fully loaded 1969 Chieftain w/ a 140 used primarily for long range cruising might use 1 prop/setup, while the same boat lightly loaded for a day of fishing/trolling would be more effective w/ a different prop. And then you add choices for stainless vs aluminum and 3 blade vs 4 blade & the list of available props only get longer.
A fully loaded Chieftain w/ a 140 probably isn't going to have the best hole shot from idle no matter what prop you put on it. Use a prop calculator to help you pick a range of props that will work w/ your boat, the 140 and how you plan to use the boat. Pick based on primary use, then if necessary, buy a 2nd prop that's better for a different use and keep it as your spare. And for most boater's its wise to carry a spare, so might as well get a prop for the secondary use AND as a spare.
zigg12001
never bin on a boat so i dont know if its fast or slow the speedo was15 mph and rpm was 3500 didnt know if i could do more or was that it
