Re: i don't get it
soooo just got the welch plugs out and they were squeaky clean. absoultely nothing in them. took a wire and stuck it up the hole. nothing
carb cleaner came straight through the
why won't my motor idle!
i still don't understand this procdure? if rotate it up after i rotate it a half revolution wouldnt the reading be a little bit off?
Once more ssslllloooowwwwwllllyyy.
I recommend you always turn the engine clockwise, so you don't tangle up the water pump.
Turn it clockwise till the #1 piston is down in the cylinder near the bottom.
Install the depth gauge and slide it into the hole a couple of inches.
Rotate the engine slowly approx 1 turn. It will push the depth gauge back so that when the piston retreats, it leaves the gauge at Top Dead Center.
Hit the Zero button on the gauge. Now you have used TDC as a 0 reference.
Push the gauge back into the hole greater than the measurement you want.
Rotate the engine slowly till the gauge reads what you want.
Set the timing pointer on the mark.
On the idle. You need.
1. good compression.
2. Strong reliable spark
3. Idle mix and timing right
4. No vacuum leaks
5. That includes bleed lines and bleed check valves.
6. Reed valves in good shape.
hope it helps
John
