It's a Force motor, but I am told it uses a mercury ign system.
Model# 906X92C, Might have a HO in front of motor, or so I am told.
Serial# 029153
Here is my problem, I have no spark. I have no power to the switch pack,(power pack).
I have checked the stator with an ohm meter and it seems to check out ok. There is a black box inbetween the stator and the switch pack, I cannot find this part in a parts breakdown. There is a ground wire and 2 wires from the stator, Green/white and white/green on on end and a single blue wire on the other end going to the switch pack. I do not have any power on the blue wire. Is there a procedure for checking out the black box? The back side of the black box looks like it has a spot that looks like it has melted and spit black stuff onto the switch pack.
Any help would be appreciated, and thank you in advance.
Serial# 029153
