Sea Raider I
Thread starter- Joined
- Nov 23, 2008
- 113
Karma gods are shining today!!! I found this gem on CL for $50!! PO's grandfather gave him this motor a couple of years ago, been sitting in his shop ever since. He decided to just get rid of it and listed it for $50, I just happened to be the first caller. Picked it up today and he gave me the outboard cart it was sitting on. He said he should have done more research before listing it for such a low price. I told him he was helping a family get on the water and also let him know this motor (even though he didnt know if it ran) was well worth $500. Woo Freakin Hoo....
I am a first time Mercury owner so bear with me...
Serial #4129433 turns out its a 75 merc in prestine condtion. Pulled the plugs (freaked out cause they look like glow plugs??) hooked up the compression guage at WOT and both cyl read 100 psi. Happy, I reinstalled the plugs hooked up the gas tank and within 6 pulls she started right up!!! Let her idle for a bit and now she starts before Im even through the first pull...
Now the questions, As I am new to mercury I noticed she wasnt peeing very well. Blew the oriface and tube out with air, and wouldnt you know it started peeing a nice good strong stream. However, at idle it seems like it stops peeing for a bit and just sputters then all of a sudden a good solid stream. Is there a thermostat in these?? or is it simply that it needs to build up certain pressure before releasing??
Unlike Evinrude/Johnson, how do I check the gear oil?? I can only see one screw even remotely similar to aforementioned units...
Additonally if you notice the "troll" switch in the pics - what is this for?? Dont fret, I will be buying a service manual but need a little advice for now.
Thanks in advance!!!
