Porschesolutions
Thread starter- Joined
- Jun 18, 2017
- 49
If you've read my posts in the past, I bought a boat from a deceased friend's brother who misrepresented the boat & has vanished. Life lesson: always insist on a test ride.
In the past year I've performed a full top end rebuild, new cap, rotor, plugs, wires, shutters, oil (4x), water impeller kit & lower end fluid. I took it out for a 10m joy test & it proved fine. 5 days later I took the family out & I'm quite sure I've spun a bearing, lost oil pressure and need a new warranted shortblock to replace what's in the motor. The engine supplier I chose requested casting numbers from the heads and block to ensure I got the correct motor.
My boat: 2000 VIP 184 Viva, 4.3 mercruiser, 2bbl carb, SN0L614688 on the flame arrestor cover.
My engine's heads: "113's" as it should have: Vortech heads with a 8-bolt Vortech intake.
My block: 14093683...683 being the key-word: this is a non-balance shaft block from 1987 I've been told by two people.
I've ready today that the harmonic damper and flywheel different for balance-shafted motors vs non-balance shafted motors...and my 683 block is not balance shafted as it should be for that era of 4.3 Mercruisers. My supplier does not have the block I need which is perhaps a 3663.
The motor was NEVER smooth and I feel a correct balance shaft Harmonic damper & flywheel was mated to a non-balance shafted SB resulting in the unsmooth frankenstein I ended up with that has since lost oil pressure & developed a rod knock early on into my only venture out on the boat longer than 15 minutes.
Questions: Where can I find a reference that shows what my correct SB motor, balance shaft, oil pan, and flywheel are supposed to be for this boat? Ugh...
