I need to replace the upeer shift saft seal on a VP 270
Maityme
I noticed oil coming from under the cover that has the 270 label on it. After rmoving the cover, I noticed the oil was coming from my shift saft. After doing research, it appears that the sift saft seal will start to leak when they get old. Quiestion is, Can you remove the shift shaft without removing the upper unit from the outdrive? It seems that the four screws can be removed and the shift shaft uit will slide out.
1984 2060 Bayliner Trophy Hard Top - Volvo AQ125B/270
adeneo
Re: I need to replace the upeer shift saft seal on a VP 270
Yes you can!
Maityme
Thanks Adeneo,
are there any tips or tricks thatI need to know about.
