imported_Mike_M2
- Joined
- Jan 17, 2004
- 174
This sucks. I was installing a new cockpit heater and got down to the last connection at the waterpump. On my 454's there's a plug just above the lower hose that comes from the motors heat exchanger. I stuck a ratchet in, turned, and she broke. The plug has the outer ridge cracked off and she ain't coming out. My choices? I could remove the pump, drill it out and tap. Lots of work, as it's a half inch galvinized fitting. It's conna take a huge bit and i don't even know if i can find a tap that big locally. I'm wondering, since this is for the water return can i tap in elsewhere? Why cant i cut the hose going into the heat exchanger and install a tee? Would it circulate right, or does it get suction from the pump fitting to help move water?
