I want hot water
amanphoto
I have a 5.7L mercruiser 350 motor. It's a fresh water boat that uses the lake water to cool the engine. I would like to install an 11 gallon 110v hot-water heater exchanger. How do I connect the how water exchanger to the to the engine?
Re: I want hot water
Ayuh,....
There's a 1/2" pipe plug in the intake manifold, right near the t-stat housing,...
That's your Hot water tap...
There's also a 1/2" pipe plug in the circulating waterpump,...
That's the return port...
cpubud
same as you would on a car to the heater-core
amanphoto
Any pics of these connections. Its a little fuzzy trying to decipher.
amanphoto
I got this picture but not sure where it goes.
Biged007
Want a ton of hot water tell your wife how much it'll cost:D
Ayuh,.... There's Nothing Fuzzy with my discription...
If you don't understand, or don't know what parts of the motor are What,...
You need a Mechanic....
You'll need 2, #3s,+ 2, #4s in your picture,...
#2 is unnecessary...
amanphoto
What is this kit actually called. Is there a part number? Does I boats carry it?
Also will this also work for heat like a car heater?
rwidman
The water heater will come with installation instructions. Make sure you buy one that is designed to use engine heat in addition to shorepower.
You can buy a heater for your boat that uses engine heat to heat the cabin. Check the catalogs.
