- Joined
- Jul 18, 2011
- 19,649
Re: Ideas/Suggestions for 'Drying Out' Bulkheads
Mid-winter update:
The 'hole drilling' in the various parts of the structure has not really provided enough evaporation of moisture. So, today, I took out the cutting wheels and opened up some surface area of the firewall bulkhead and center engine stringer, as those were the areas of highest moisture concentration.
Here are a few photos of the progress. . .
Cut-out lines made with the cutting wheel on the center stringer . . . this is the same area where I had drilled a couple of holes to get a direct moisture reading.
Then it was a matter for the hammer and chisel . . . along with a pry bar. Here is the wood core exposed . . . pretty wet.
I made a bigger cut-out area on the bulkhead. . . I was expecting to see some rot progression in this area, but it was still solid and managed to put up a bit of a fight.
I am glad that I am doing this now, instead of a couple of years from now
. I will probably open a couple more areas next weekend, when I have some more time to 'play'.
The game plan would be to then apply heat and ventilation to these exposed areas to more aggressively 'pull' water out of the wood structure. We shall see how it goes. . .
Mid-winter update:
