Ideling problems
crawdad
I have a 50 hp evinrude # E50TLCO that I got used from a friend. Just recently I starting having problems with my motor. It starts fine but after about a minute it idles down and shuts off. I'm not sure if I should take it to a shop or if this is something I should be able to do myself. It idles off, wether in gear or nuetral. I also noticed some oil leaking from the mid section. Does anyone know what the problem might be. Thanks in advance.
HighTrim
Re: Ideling problems
The oil leaking around the gearcase is likely carbon, an unburnt fuel/oil mix, but have a read here to determine.
http://forums.iboats.com/showthread.php?t=207285
It sounds like you are having a fuel delivery issue. Will pumping the fuel primer bulb keep it running? Spraying pre mix into the carb throats?
Let us know what you find
crawdad
I pumped the prime bulb while it was running and it ran fine for about 2 mins then died out. I checked the gas filter and it full so it's getting gas from the tank, but it's still cutting out. I aslo noticed the water the comes out from the impeller was real weak it wasn't a solid stream like before?
