Ignition coil overheating - Mercruiser 140
bruceb58
Re: Ignition coil overheating - Mercruiser 140
Is part of that suggestion keeping the points?
Same question I would have. Unless the new coil has an internal resistor, you have to keep the external resistor.
DJ Jaws
The points are a non-issue here. Just remove the coil, the resistor, and the wire that runs between the two, and get a 12V coil. Problem solved, along with some other ones down the road. The only drawback to this is that you may have to put beefier spark plugs in it that can handle the extra power.
:facepalm:
:facepalm:
Ayuh,.... I believe there's atleast Two posters in this thread, that have No idea how a points fired ignition works,..... ;)
bruceb58
Only 2? There is a lot of wrong info in this thread.
Please help me understand, how the increased current on the points would not were the points out faster. All points system I have ever found use a resister. Not saying they are not around but I have never seen one
bruceb58
You are correct. You need a resistor. Its either external or in the coil.
stratcat88
Any other ideas about why my coil is burning up?
tach. my tach worked fine too on my first engine. we would be running for a couple of hours and start idling and the engine would start runnin rough then you would see a big spark from pos. to ground and the engine conked out.and would not restart. read some where in this forum that the tach could be the problem so start there so i did and changed all my gauges. never happened again. changed engine cause Don S said after looking at a few pictures of the engine, that i was riding on a BOMB! first salt water boat. i heeded his warning. GOD BLESS DON S.
thumpar
My reply was to the plugs needing replaced with a different coil.
bruceb58
To test if your tach is an issue, just disconnect it.
stratcat88
thump, you are most likely right. first year with a mercruiser and dont have the experience all y'all have. when i read someones thread that sounds like something i just went through i,ll just share it.
boozer1966
Maybe it needs a new flux capacitor.
splatter
Did you get this issue resolved ? If so please share how . I'm having the exact same problem .I have new points,plugs, wires,rotor button , condenser , all put on at the end of last year . This trouble started when I put the boat in this year . So far I have replaced my coil , and condenser as well as checked the gap on the points and plugs.issue is still there . my thread is here
http://forums.iboats.com/mercruiser...ercruiser-missing-after-gets-warm-645870.html
MikDee
Banned
Oops! I just posted to that link, please check it out:
