Nandy
- Joined
- Apr 10, 2004
- 2,145
Re: Ignition Switch Wiring
if you are seeing gas in the water i have to assume that at that time your motor is flooded. I mean, seeing some gas is ok, but a huge means that the gas is flowing but not burning. I would not say it is spark... If squeezing the bulb help then you have a fuel starvation problem.
Make a new post in the motor forum under your motor model. You can probably cut and paste your initial fuel question. Some of these problems are hard to tack from a distance, but we will get it somehow. You can post here the link to the new thread.
When it doesn't start the prop is leaving a huge amount of gas/oil in it's wake. So it's gotta be getting some...
