Rob the weekend warrior
Thread starter- Joined
- May 24, 2012
- 33
OKAY back at my tub-is there a fuse in the ignition between the switch and the assist solenoid? I have power in and out of the ignition key switch "s" works fine-get 12v there when I turn the key-jumped it around the switch-nothing. I figured that it was the assist solenoid, so I went over to that, and jumped around the assist solenoid-cranked just fine, brought 12v off the battery to the switch terminal on the assist solenoid, and it cranked. It is simply the wire that is between the switch and the assist solenoid. before running a rogue wire outside of the harness, I want to see if there is an inline fuse between the switch and the assist solenoid. It is highly unusual for a wire in a loom to simply go bad so that is why I ask.
