paparoof
Thread starter- Joined
- Apr 22, 2010
- 730
Re: I'm an owner! 1975 Islander 22
Okay, okay, I'm back at it again. Couldn't let the long weekend go by without getting something accomplished on the old girl.
A couple weeks ago I went and sat in her for 45 minutes and made up a to-do list. This is not necessarily in order, just stuff that I thought about while staring.
Order two new fan belts
Order gimbal pin removal tool
Order bellows kit
Order exhaust tube flappers
Buy new/repair old fuel tanks
Buy new lights (if)
Buy switch panel
Buy starter battery
Buy battery switch
Buy new thermostat/gasket
Order blower hoses
Order new blower motors (if)
Remove motor
Install new fan belts
Pull gimbal housing
Replace bellows
Install exhaust tube flappers
Reinstall angle aluminum at top of transom
Remove/5200/reinstall transom bolts
Reinstall motor
Align motor
Reinstall outdrive
Wiring harness inspect
Wiring harness repair
Test lights
Install new lights
Remove console (?)
Install switch panel
Complete console installation
Reconnect/test console wiring
Build battery trays
Install battery power
Install new thermostat
Inspect pepcocks (one's broken, get from old motor?)
Compression test
Pull floors
Clean inside hull
Fill hull with water leak test
Gluvit
Install flotation
Install deck
Rivet deck
Glass deck (with sand)
Paint deck
Test original blower motors
Then I spent a couple weeks being depressed about how long that list is.
Order bellows kit
Buy new lights (if)
Buy switch panel
Buy starter battery
Buy battery switch
Order blower hoses
Remove motor
Pull gimbal housing
Replace bellows
Reinstall motor
Align motor
Reinstall outdrive
Test lights
Install new lights
Remove console (?)
Build battery trays
Compression test
Pull floors
Clean inside hull
Gluvit
Install flotation
Install deck
Rivet deck
Paint deck
