sebagolake19
Thread starter- Joined
- Apr 11, 2008
- 32
I've been working on fixing a temp problem with my boat. My boat is a closed cooled system that runs really well but the temp gauge reads low. The gauge was reading 110 degrees the first time I took the boat out this year. I removed the t-stat and replaced it with a new one then ran the boat on the flusher ears. The boat ran about 130 degrees when it was fully warmed up. I know this because the hose below the t-stat was warm indicating the t-stat was open. I took the old t-stat and tested it by placing it in some water and heating it up. The old t-stat opened right up. So I took the wire off the temp sender and grounded it to the motor. That pinned my temp gauge as far to the right as it could go so I know the gauge works. I ordered and put in a new temp sender. Started the boat again on the flusher ears. Let it warm up for a while and guess what.... The temp gauge only read 130 degrees. The hose below the t-stat was very warm so I know it was reaching 160 degrees at least. Is there something I'm missing???????
