I recently purchased a 2005 Bayliner 185 with the Mercury 3.0 and Alpha one Gen 2 drive. Since the impeller had never been serviced I decided to replace it. I followed the service instructions carefully, making certain to turn the driveshaft clockwise while pushing the stainless steel housing over the impeller.
After reassembly, I hook the muffs to the drive and start the engine. I notice right away that there is no discharge water. After running for a while I notice a burning rubber smell and kill the engine. I knew I fried the impeller.
I dissasembled the drive again to look at the impeller. There are little pieces of rubber in the pump housing and one of the impeller blades is kinked like it was spinning the wrong way.
What is going on? Why won't the pump pull through water?
