hmm, I've seen that diagram before. My unit had another o-ring type thing with a spring wrapped around it and I figured that is what it was talking about. I guess I now have a different extra part![]()
This is the other one that was originally there. It was actually about halfway down the shaft; I just figured it wasn't pushed down all the way. There was an o-ring in the groove that I replaced.
Take that O-ring out and throw it in the trash..... AChris will provide more info if needed. Check out this thread...
http://forums.iboats.com/showthread.php?t=532476&p=3638290#post3638290
KTB
He said he replaced the O-ring on the shaft....I am passing along the lesson learned from AChris....It's not an oring, it's the inner portion of the outer seal in the upper half of the gearcase.
The seal is item a in the picture below (from the manual)
