In with the new and do what with the old?
SKIBUM1M
Re: In with the new and do what with the old?
Do quick compression test on the motor and that will let you know where you stand on the motor internals. Just a $15 guage at autozone and all the doubt is gone.
HVAC Cruiser
Hey Vert,
I just thought of it, Do you want the 305 I just pulled? I'll give her to ya for spare parts after I pull the accessories off it it had good compression, and all If you are staying with a 305 it might be easier just to have the crank cut on this one its a closed cooling fresh water motor.
P.S I'm impressed is that a snap-on ratchet I see on top of that air cleaner.
HVAC Cruiser
Thanks Vegas, yeah the interior will do for now. I just want to make sure the transom is good and then I will be happy. Floor is solid and stringers appear to be good but still need to be checked out. I started messing with the motor today and found some problems but that is easy stuff compared to full restos.
Hey Vert, Your boat has a "FLOOR" lol just messing with ya man :D
83vert
I cant believe that I did not catch that. LOL. The DECK on it is solid though, still not sure about the floor yet. I will take that 305 off your hands when your ready to part ways with it, just let me know.
HVAC Cruiser
Hehehe sorry I couldn't resist lol.
Sounds good with the 305, I started stripping her tonight, looks like it was a fresh motor. New paint, really no carbon buildup on the exhaust valves or runners. You might be able to have the crank cut, put a new set of bearings in her and run with it. You still have my private info? I'll shoot you an e-mail with it later just in case
83vert
Well after a long winter and the install of a new fuel pump, starter, alternator, circulator pump, tune up, exhaust, thermostat housing, battery, and two new belts I got the boat running today. I hooked up the muffs and started it and thats when I realized a leak from the starboard manifold elbow drain. The P/O overheated and must have melted the plastic drain so I will try and replace it tomorrow and shoot some video for you guys. I also donated the Chaparral to a guy that will be turning it into a duck hunting boat :eek:. It feels good to be finally catching up on things :D
BobsGlasstream
Well after a long winter, It's good to see you back.:D
Keep us updated.
Bob
83vert
The Stingray is now ready for a sea trial. I had to replace the carb and it is now running great. The bottom of the bench seat was totally rotten so I made up a new one and just need to find some gray carpet to rap it in.
I posted this on the Merc forum but figured you would get a laugh out of the old carbs internal fuel filter.
SKIBUM1M
You didnt need a carb, That is dessicant to keep the fuel dry. lol
sprintst
Nice to see the boat back in action again.
I would have loved to get my hands on a boat like that.
BobsGlasstream
Hey Vert,
That fuel filter does look like crap.
You can get Grey /O carpet at Lowe's.
Glad to hear she is running good.
Take care.
Bob
83vert
Here are some updates. I still have not gotten the boat in the water due to some seriously needed outdrive help
The new Gimbal is in and the rebuilding process is underway.
HVAC Cruiser
Hey Vert
Im finished with the alignment tool if you need it. I am going to Port Jeff this afternoon but I will leave it along with the welded up 9/16 on my front porch by the battery charger I have there.
Bill
83vert
I am making some great progress as of lately. The transom assembly is all back together with brand new SEI trim cylinders installed.
I split the outdrive today and installed a brand new water pump kit and sanded down the upper and lower for there new paint job.
Thanks to HVAC cruiser for the tools to get this far and some of his tips.
BobsGlasstream
83vert,
Nice progress. You will be back in the water before you know it.
Bob
83vert
Thanks Bob.
I got the outdrive all back together and installed without a hitch. What do you guys think? Here is some video-
83vert
Now all I need to do is order the rug for the bottom of the bench seat and put the interior back together. Hopefully next weekend or a week night I can be in the water for a trial run. Here is one more vid :D ( I could not help myself).
fat fanny
Sounds really good vert. Man one of these days I will run across a deal like that
