Inboard engine removal instructions
wep32907
Can any one help me with how to remove my 3.0 mercruiser from my 1976 cheetah like step by step or picture digram
Re: Inboard engine removal instructions
Ayuh,... Have ya been up to the Adults Only section at the top of this forum,..??
It's All in there,...
This would be a real big issue to put in words and/or pictures. We can't see your boat and even if you show pictures this would be a tall order. Some of the basics are:
Remove outdrive, fuel line, shift bracket with cables, starter cables, ground cables, electrical plug, everything else attached, unbolt motor mounts, support engine, lift, etc
Sure like to know how you do that, I refresh the page and nothing, post and there is only me, look back hours later and yours is ahead of me. No one replied to his post so hence the reason I tried, if I would have seen you answer it I would not have posted.
Ayuh,... The time stamp says yer were still typin', 2 minutes after my single digit post,.... :D
Donno why ya didn't see it with the refresh,...
