Re: Inboard engine removal instructions
This would be a real big issue to put in words and/or pictures. We can't see your boat and even if you show pictures this would be a tall order. Some of the basics are:
Remove outdrive, fuel line, shift bracket with cables, starter cables, ground cables, electrical plug, everything else attached, unbolt motor mounts, support engine, lift, etc
