Sorry, been out, & busy all day, just got in,,, Home Depot, & hardware stores, sell small aluminum sheets, that have a hollow pattern cut in them like lattice, or, perforated speaker grill material, that you can bend around to form a cap to fasten to the transom then run the pipe thru that, it will do 2 things, be a support for the pipe, and be ventilated to help cool things off, & dissipate heat., But you still need a plate to cover the exposed fiberglass, & wood, sandwich material of the transom undermeath, first I think. So, as you see this gives you extra work rather then just putting a metal sleeve in the hole, around the exhaust pipe as you originally had it.
Not a lot to report on the "SHAKER" project today, the wife decided to spring clean the garage in the middle of January.But I'm better off for it, at least I can walk all the way around the boat now!
LOL! Tell me about it, we do this often, & it still don't help!
The "SHAKER" is really coming along well! Yes, a piece of perforated of some type, aluminum bent into a U, then slipped over, and resting on the transom, screwed down, with the exhaust pipe running thru it should do the trick!
By the way, the fuel tank looks good, but a bit small considering,,,lol,,, Have you given any thoughts to a tiller, or rudder?
Man I've got that rudder all figured out, been puttin together different idea's that I got here from you guy's. It'll be a little while coming, but I think you'll be impressed when you see it! It'll be a little different!
I'll carry spare gas for now til I see how it does. If it' like my old eight horse out board riding lawn mower engine, I used to get a three hour trip on about a gallon, gallon a half I think it was out rock fishing in january when it was rough and windy, hope this one will be that good!
Cut the access hole for the throttle and key switch in the seat tonight. Took about an hour and a half, an hour of that was digging the foam out from under the seat, hard stuff to get out! Gotta pick up something to cover it with tomorrow. Then mount switch plates on top of that. Got good access to my wiring this way.
Cut the throttle and key switch trim plates out of the the old riding mower dash tonight, came out pretty decent. Here's you a look!![]()
Me too! The new smart boat.
Hey there -- really enjoying this thread (taken about four evenings stolen time here and there to read it all) and best of luck to ya Maxum!
Coupla things. I heartily endorse any ideas to cover as much of that exhaust as possible. Out there with the little boat rocking and such, it's only a matter of time before you put your hand smack down on that pipe.
Also, it's electric start right? Have you given any thought to your battery location? Maybe not that critical but as you plan out the rest of the rig, don't forget that.
And lastly -- are you going to seal up that wood at all? Be a shame for it to become a soggy mess after all that work. I'd consider glue and screw for it considering the vibration factor.
That's it -- back to my recliner to watch and enjoy!
Yep! Panel looks good. Take your time now on the L U wish I was there , Then again if I was you'd probably have clouted me with a wrench by now.
Down where? I'm 21 hours north of vancouver B.C. Can. The price of fuel here sucks.On vacation for nine days starting Friday evening,maybe I'll get the lower unit finished up during that time. Got the pocket for the air vent screw glassed in tonight, ready to turn the boat over and start grinding and glasssing. Come on down LD we'll finish it up!
