Re: Inboard outboard air cooled engine
Sure it will. If in doubt add a couple more blocks to the system. But I have seen a quad picked up off the ground with a 3500 winch with 1 snatch block on it. You should not have a problem. Except to make a strong pull point on the boat.The muffler looks kind of cool but I think it would be a little tight in the boat. Didn't do much on the boat this weekend , spent most of my time with the family! I did drag out the electric wench tonight and clean it up a bit. 3500 pound capacity, you think that will haul the ole "SHAKER" out of the water and into the back of the truck?Still unsure if I'll use it but I am thinking it over!
