69GlassparMan
- Joined
- May 7, 2005
- 41
Okay, As you know I have installed a tower of power . More exact a 1969 1250.<br />Today I installed bilge pump. Went perfect.<br />then decided to tackle my power tilt unit.<br />Well first thing I cleaned out hoses. Then setup a fabricated mounting area for main unit. Then I filled per selco manual the fill hole with 5-30 oil. With vent open I tested unit and it works as advertised. I tried full trailer, down and up a few times then refilled oil and closed vent and oil hole. Seems to work GREAT. I see no leaks are apparent.<br />The one problem I do have is that when I got motor tilt pin was in first hole from transom. I moved to second hole and when I operated the power tilt unit it came down on tilt pin (acutally the nylon behind motor belt did) and bent pin abit. Now I need a new pin or possibly just straighten mine. I am guessing this happened because unit wanted to go lower. I do not see an adjustment to keep it from going down on pin. Actually no since it bent pin I dont think it wants to go any lower. <br />Any ideas. Also does anyone have a tilt pin for sale?<br />Other then that I have left it up in trailer to see if it stays up. <br />Thanks<br />Tod
