Intake Manafold
m_gdavis
I received the gaskets I need to replace my head gasket on my 99 mercruiser 5.7l carbarated engine.
I have a couple of questions:
Does the Intake manafold gaskets go on dry? Without any gasket sealer?
Also there was some kind of silicone between the Intake manafold and block. It was a fairly thick bead.
Do I just use high temp gasket maker? (like PERATEX Ultra BLack Gasket maker)
Thanks
Re: Intake Manafold
Ayuh,... If you bought a Quality set like say Fel-Pro's,...
The gaskets go on Dry...
RTV is used alone on the front,+ back of the manifold, where it meets the Block...
If you use the gasket strips provided,...
RTV must be used at the ends where the strips meet the gaskets...
m_gdavis
Re: Intake Manafold
Thanks
I bought Quiksilver gaskets. I'll put the gaskets on dry and use permatex on the intake to block gap.
n2ostroker
Re: Intake Manafold
Use rtv on the ends, the rubber can slide out then you have to do the process all over again. I use a little gasket adhesive on the intake gaskets at each end just to keep it from wiggling around and becoming misaligned.
dr_bowtie
Re: Intake Manafold
I dont use the end rubbers at all...just put a 3/8in bead of RTV down and then set the intake...leave what oozes out there...thats what the factory does in the mid/late 90s...
BOTH surfaces MUST be clean and free of grease....it wont leak
Bt Doctur
Re: Intake Manafold
I use a bit of permatex aviation around the water ports in the head when I install a manifold.Hasen`t failed me.
jtybt
Re: Intake Manafold
Yeah. Older flat paper gaskets...good idea to use permatex around the water passages in the ends.
wca_tim
Re: Intake Manafold
nothing around the water passages, nothing on the ends but a nice bead of rtv....
dan t.
Re: Intake Manafold
do not waste your money on plastic based vortec intake gaskets, the felpro aluminum based gaskets are the only ones worth using, that way you only have to do it once. I bet the old gaskets were plastic based and collapsed. what do you think more plastic ones will do
John_S
Re: Intake Manafold
Unless Merc changed them, it is just the GM plastic/silicone ones they have been using from the start.
