Davinciman
- Joined
- Feb 25, 2009
- 67
Re: Interlux paint HELP needed
You could probably wet sand the last coat to remove any orange peel and then buff it out with polishing compound to restore the gloss.
After you sand with 400, are you getting any scratch marks?
If so you could go up through the numbers, ie 600, 800, 1000 then polish.
Looking forward to some pictures of the "perfection".
Good luck
Well i put my first coat on saturday morning came out pretty good had a few runs but most of them layed down and dissapered. Let it dry until monday afternoon when i wet sanded with 400 grit. Put on my second coat this time i used the foam roller instead of the brush to tip. Much better results although there is some very minor orange peel but this is no show boat! I will let this dry for a day or two then wet sand again and put my final coat on! my question is what should i do when the last coat dries wet sand? leave alone? thanks tail_gunner for the foam roller tip worked great![]()
Good luck
