Capt dave 258
- Joined
- Jul 14, 2021
- 92
Greetings. I have a 1986 Johnson 110hp that I recently picked up. I deleted the VRO and mix oil with the gas. I have an alarm that goes off within a minute of starting the motor. It's not a constant beep but it's intermittent. The alarm comes from behind the steering wheel in the helm compartment. Is that going off due to the VRO being bypassed? I replaced the impeller, thermostats and pop-up valves, all of which looked good. Water seems to be circulating fine. I don't believe it's overheating but I'm going to put a thermal tester on it later today to verify that. Hoping the alarm is due to the VRO bypass and I can just disconnect it. Thinking that if it was an overheating alarm it would be constant and not intermittent. Thoughts?
